How to run mixed-signal simulation without graphic interface
joskin
Member level 1
Mixed-signal simulation
How to run mixed-signal simulation without Cadence graphic interface?
I use Cadence4.x to run circuit simulation.You know,when successfully run the simulation once,the tool automatically create a executable file named 'run????',wherr ???? is the simulator's name.For example,when I run Hspice in Cadence,the executable file name is 'runHspice' and I can type 'runHspice' in command line to run the simulation without Cadence interface.
Now I run VerilogHspice for mixed-signal simulation,but when I type 'runVerilogHspice' in the command line,it deosn't work. Can anyone tell me why and how?
