bravo11
Newbie level 3
library IEEE;
use IEEE.std_logic_1164.all;
use ieee.numeric_std.all;
entity PowerControl is
port (
Clk : in std_logic;
Reset : in std_logic;
ms : in std_logic
-- xbus_hw_idct enable bit
pse_m : out std_logic);
--IDCT switch and isolation control power shut off
end;
architecture rtl of PowerControl is
type state_type is (S0, S00, S01);
signal state_m,nstate_m: state_type;
signal m:std_logic;
signal c_delay_cycles_S00,n_delay_cycles_S00: natural range 0 to 2; --delay counter for mode 0
begin
seq: process (Clk,Reset,nstate_m,n_delay_cycles_S00)
begin
if (Reset == 0 ) begin
state_m =S0;
end else begin
falling_edge(Clk) then
state_m =nstate_m;
c_delay_cycles_S00 =n_delay_cycles_S00;
end ;
end process seq;
comb_m: process (ms,state_m,c_delay_cycles_S00)
begin
case state_m is
when S0 = --Starting State
n_delay_cycles_S00=0;
m ='1';
if ms= "0" then
nstate_m<=S00;
elsif ms= "1" then
nstate_m<=S01;
else
nstate_m<=S0;
end if;
when S00 => --Mode 0 - Block OFF
if ms = "1" then
n_delay_cycles_S00 <= 0;
m<='1';
nstate_m<=S01;
elsif ms= "0" then
if c_delay_cycles_S00 < 2 then
m<='1';
n_delay_cycles_S00 <= c_delay_cycles_S00 + 1;
else
m<='0';
end if;
else
m<='1';
nstate_m<=S0;
end if;
when S01 => --Mode 0 - Block ON
m<='1';
if ms = "0" then
n_delay_cycles_S00 <= 1;
nstate_m<=S00;
elsif ms= "1" then
nstate_m<=S01;
else
nstate_m<=S0;
end rtl;
port (
Clk : in std_logic;
ms : in std_logic
end;
signal m:std_logic;
begin
begin
state_m =S0;
end else begin
state_m =nstate_m;
end ;
end process seq;
begin
case state_m is
m ='1';
if ms= "0" then
nstate_m<=S00;
elsif ms= "1" then
nstate_m<=S01;
else
nstate_m<=S0;
end if;
if ms = "1" then
m<='1';
nstate_m<=S01;
elsif ms= "0" then
m<='1';
else
m<='0';
end if;
else
m<='1';
nstate_m<=S0;
end if;
m<='1';
if ms = "0" then
nstate_m<=S00;
elsif ms= "1" then
nstate_m<=S01;
else
nstate_m<=S0;
end rtl;
