+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Advanced Member level 1
    Points: 2,690, Level: 12
    Join Date
    Dec 2010
    Posts
    415
    Points
    2,690
    Level
    12
    Calculate a Mixer frequency Response
    hello
    for example you assume that we have this circuit
    now how can we defined the bandwidth of transmitter before inject the audio signal and after that?
    could you tell me theory of this calculation?
    •   Alt29th April 2012, 20:51
      advertising
  2. #2
    Advanced Member level 5
    Points: 34,469, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,667
    Points
    34,469
    Level
    45
    Blog Entries
    7
    Re: Calculate a Mixer frequency Response
    Estimating the FM sensitivity is not an easy thing to do unless you have the large signal model of the device.
    I don't know for sure but it appears the above design of a Colpitts Osc will change freq with the device Miller capacitance on the collector. modulating the current in Q1 affects the gain bandwidth product (GBW) and presumably the collector capacitance.
    This non-linear characteristic is like a tuning diode that is DC voltage controlled except not well defined and overall very sensitive to the location of the antenna near L1 and the layout of the board. I'm not sure how from looking at the specs.
    http://www.datasheetcatalog.org/data...cs/mXqwswz.pdf
    http://www.datasheetcatalog.org/data...ips/BF494B.pdf
    I would choose another design more stable with more linear design characteristics such as a varicap tuned VCXO or VCO
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
    1 members found this post helpful.
