+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 6
    Points: 2,970, Level: 12
    Achievements:
    7 years registered
    Join Date
    Jul 2010
    India
    Posts
    330
    Points
    2,970
    Level
    12
    AVR studio doubt wrong result
    Can anyone please explain why the result of the operation given below is always wrong
    unsigned long var = 0;
    var = 10*9600;
    The result comes as 30464. I have even tried by changing the data type of "var" to double.
    Waiting for a solution...
    "I have no special talents. I am only passionately curious." Albert Einstein
    Regards,
    Embedded_Geek
    •   Alt8th April 2012, 14:14
      advertising
  2. #2
    Points: 6,702, Level: 19
    alexxx's Avatar
    Join Date
    Apr 2011
    Greece
    Posts
    1,011
    Points
    6,702
    Level
    19
    Blog Entries
    Re: AVR studio doubt wrong result
    Quote Originally Posted by Embedded_Geek
    var = 10*9600;
    Try this:
    var = 10ul*9600ul;
    That should work.
    1 members found this post helpful.
    •   Alt8th April 2012, 14:26
      advertising
  3. #3
    Full Member level 6
    Achievements:
    7 years registered
    Join Date
    Jul 2010
    India
    Posts
    330
    Points
    2,970
    Level
    12
    Thank you very much alexxx. It worked fine as you said but can you explain me why 10*9600 is not working. I mean I have used this kind of statements in IAR, RIDE etc.
    Regards,
    Embedded_Geek
    •   Alt8th April 2012, 14:30
      advertising
  4. #4
    alexxx's Avatar
    Join Date
    Apr 2011
    Greece
    Posts
    1,011
    Points
    6,702
    Level
    19
    Blog Entries
    Quote Originally Posted by Embedded_Geek View Post
    I also do not have such problems in IAR. GCC is an older and more "strict" compiler. The problem is that when the compiler sees raw numbers < 65536, then it interprets them as 16-bit.
    So 10*9600 = 96000 = 0x17700.
    But since this result is interpreted as 16-bit, then the remaining result will be 0x7700 = 30464. You have to use this "ul" to declare that this is an unsigned long value.
    Depending on the value you can use ui for 16-bit, ul for 32-bit and ull for 64-bit values.
    Alexandros
  5. #5
    Full Member level 6
    Achievements:
    7 years registered
    Join Date
    Jul 2010
    India
    Posts
    330
    Points
    2,970
    Level
    12
    Where can I find this kind of restriction regarding gcc?
    Regards,
    Embedded_Geek
    •   Alt8th April 2012, 14:45
      advertising
  6. #6
    alexxx's Avatar
    Join Date
    Apr 2011
    Greece
    Posts
    1,011
    Points
    6,702
    Level
    19
    Blog Entries
    Try google with "integer constant suffix" as keywords. This is not only a GCC issue but a C issue in general.
    I've googled a couple of references to get you started:
    http://msdn.microsoft.com/en-us/library/2k2xf226.aspx
    http://www.delorie.com/gnu/docs/gcc/cpp_48.html
    About the second reference, look at the bottom of the page.
