+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 5
    Points: 195, Level: 2
    Join Date
    Apr 2012
    Bangalore
    Posts
    8
    Points
    195
    Level
    Matlab code for Bit error rate of turbo coded ofdm system on AWGN channel
    Hi all
    Can u help me?
    I need the "Matlab code for ber of ofdm system using turbo codes on awgn channel.
    If you have the code plz send it to "sweettttiiii@gmail.com".
    Its urgent plz
    Thanks in advance
    •   Alt5th April 2012, 13:32
      advertising
  2. #2
    Points: 7,067, Level: 20
    klystron's Avatar
    Join Date
    Jul 2002
    South Africa
    Posts
    1,014
    Points
    7,067
    Level
    20
    Re: Matlab code for Bit error rate of turbo coded ofdm system on AWGN channel
    Share with us your attempted code and indicate your problem areas
    1 members found this post helpful.
    •   Alt5th April 2012, 14:08
      advertising
  3. #3
    Newbie level 5
    Join Date
    Apr 2012
    Bangalore
    Posts
    8
    Points
    195
    Level
    Quote Originally Posted by klystron View Post
    Actually i am new for matlab. I found the code for OFDM as well as Turbo codes but i am not able to combine them to get turbo coded OFDM. Can you please help me in this???
    •   Alt17th April 2012, 12:04
      advertising
  4. #4
    Full Member level 4
    Points: 1,209, Level: 7
    Join Date
    May 2011
    NY
    Posts
    192
    Points
    1,209
    Level
    7
    Can you post the exact code? tell what you did exactly...and we could go on from there.
  5. #5
    Newbie level 5
    Join Date
    Apr 2012
    Bangalore
    Posts
    8
    Points
    195
    Level
    I have the following code in which convolution encoding is used with ofdm instead of turbo codes..
    I have the turbo codes in simulink.
    Can you please help me to put turbo code instead of convolution code???
    its urgent please help me
    http://www.mathworks.com/matlabcentr...content/OFDM.m
