Interfacing GPS module with RS232 with PIC 16F877A and transmit the received data
sanoopgr8
How to interface GPS module with PIC 16F877A (MPLab IDE and HiTech C v9.8)
my game plan is this
* Receive the NMEA data from the GPS module baud rate 4800
*Store it in a buffer in PIC 16F877A xtal 10MHz
*Transmit the received dat via Bluetooth baud rate 4800
here is the source code
#include <htc.h>
__CONFIG(LVP_OFF & BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_HS);
unsigned char DATA;    //serial data buffer
void interrupt isr(void)
  if(RCIF && RCIE)
    DATA = RCREG;
    if(TXIF)
      TXREG = DATA;
void main(void)
  ADCON1 = 0x06;    //all port pins digital I/O mode
  TRISB = 0xff ;     // set PORTB as INPUT
  PORTD = 0 ;    //clear PORTD output latch
  TRISD = 0 ;     // set PORTD as OUTPUT
  TRISC = 0b11000000;  //PORTC output, RC6 UART TX, RC7 UART RX
  SPBRG = 0x81;    //baud rate 4800bps w/10MHz xtal
  TXSTA = 0x24;    //asynchronous serial mode, enable transmit, high speed BRG mode
  RCSTA = 0x90;    //enable serial port, enable continuous receive
  PIE1 = 0x20;    //enable serial receive interrupt
  INTCON = 0xC0;    //enable peripheral interrupts, enable global interrupts
  //main code begins here
what i want to know is how to set up the hardware for this purpose dose my code work out or i need to change anything ?
I dont follow Malay anyway google translator is there :)
btw is my code not useful at all ?
What you mean your code not usefull? That is only a piece of code, just receive UART. You still need to processing that.
i just want to receive it and re-transmit it via bluetooth of same baud rate
you can do it.... just use RX pin to receive then TX to transmit through bluetooth. Do not forget to connect Ground for both.
