Help needed on basic Verilog coding--"for looping"
Renjie
Newbie level 5
Hi guys,
I'm trying to test a 5*5 multiplier; and the two inputs are required to cover all possibilities. So I use two for looping like this:
module tb_mult5x5();
reg [4:0] InA=0, InB=0;
wire [9:0] Product;
integer clk,fp;
mult5x5 mult(InA,InB, Product);
initial begin
for(InA=0;InA<=5'b11111;InA=InA+1)begin
for(InB=0;InB<=5'b11111;InB=InB+1)begin
#1; end
end
#5;
$stop;
end
After simulation, I notice the InA was stuck at 0 and InB goes from 0 to 11111 again and again, obviously the processing can't jump out from the second for looping.
Can anyone figure out what's going wrong here?
Thanks!
Dude there is no clock !!!
put the clock like this
initial
clk <= 1'b0;
always
#5 clk = ~clk;
Then try this code.
I think the problem is not in the clk signal... because you dont need it to simulate a pure combinational multiplier...
The loop never stops because the condition is always true. Let's see.... InA = 11110, 11111, 00000, 00001.. and again, and again.... :-D (the same things actual for InB loop)
To solve the infinite looping you need to extend InA and InB with one more bit and send to your multiplier only InA[4:0] and InB[4:0].
Good luck!
You can also debug this in the waveform viewer of the tool that you are simulating with.
If this does not help,let me know
Can you explain in detail, how did you solve it and what was the exact problem so that we all benefit.
Thanks
sure, just like exactly Alosevskoy pointed out, the InB is 5 bit; however in the for looping, the boundary condition is InB <= 11111, it will always be true. That's why it won't get out of the loop. Simply we just change the bit of InB, then it works.
