Crystal Oscillator Design
Qube
Member level 5
HI, i Just wanted to understand this circuit better and discuss with people
So here it is a ,crystal oscillator...
It uses a 3.5Mhz Crystal... and takes feedback from emitter of the transistor ,using a Capacitive Voltage divider...
And it has 50pF Variable cap,i think it is to tune the frequency of the oscillator,am i right??
my another doubt is there are 2 capacitors 270pF and 150pF,do u think that will add up to the frequency ???
Please correct me ,if i am wrong and also explain it's working in brief for my better understanding
"my another doubt is there are 2 capacitors 270pF and 150pF,do u think that will add up to the frequency ???" They will have a very small (+-10HZ) effect on the frequency but a huge effect on the output level and if the oscillator will oscillate at all.
Frank
On your schematic, the Colpitts-type oscillator is shown. The capacitors between transistor base and ground are calculated for a coil in place of the quartz crystal. The L1 in collector is tuned by 250 pF variable capacitor to resonate at 3.56 MHz for a good oscillation. Fine tuning can be done with 50 pF VXO in series with the quartz.
Find a textbook on the basics of RF electronics to learn how oscillators function, and try to make experiments. Try ARRL Radio Amateur's Handbook, you can find a lot of good stuff, and well explained.
