enemra
Junior Member level 1
Dear all,
I am doing my final year BE project now (next sem). I am stuck with something here. The requirement is something like this-
I have 4 input lines which gives out clk pulses with diff voltage levels. I must be able to map a particular input to output with select lines as in mux. In mux, the output will be 0 (0V) or 1(5V) depending on input but I want the same voltage level of the input in the output.
In simplified words, I want a mux whose input wil vary between 0-12V and I want to get the same in output where I must be able to select a particular input line with select lines.
Relay will be a solution, but i don't want to go for mechanical.
Any other solution with IC, tranistor,Latches, etc?????
