PIC Microcontroller Interfacing
basitccp
Junior Member level 1
Pakistan
Can any one tell me how to interface pressure sensor (24pc01smt) with pic16f877a ..???
THNx for replying but i dnt knw any thing about this sensor i have read all data sheet but i cannot find any thing..CAn u tell me how to calibrate it and if u have any idea about its coding then plz tell me ....
First the ground of the circuit ie sensor and micro controller should be common. then you connect the output of sensor to micro controller pin and check weather the sensor is responding for 1 of zero by glowing some led or something else. example is as below:
if(PORTB.F5==1) //If sensor output is 1
PORTE.F2=1; //Glow led
if there is no response then check following
if(PORTB.F5==0) //If sensor output is 0
