STA tool constraints and the syn constraints
qjlsy
Member level 3
syn & sta
Is STA used for checking whether each APR's result meet the constraint of syn which are used to produce current APR's input?
As we know, during the iterations between syn & backend, each syn. turn uses different constraint. So does it mean in each STA turn, should STA script be changed to comply with the syn script used to produce current APR's input?
Thanks a lot!
Re: syn & sta
hi,
sta constraint should consistent with syn constraint.
Re: syn & sta
Thanks a lot for your confirmation! :)
Re: syn & sta
hi,
you r welcomed.
btw: as I know, in 2004.06 version, the timing engine in PC is the same as PT.
Re: syn & sta
yes,
but I think STA tool is not only usded to generate input for APR,using it to analyze timing of post-layout netlist is main popurse.
Re: syn & sta
There are two purposes for STA tools:
1) Generating constraints for layout tool. Synthesis tool can generate it too, but it contains too many other commands which are valid only in synthesis tool.
2) Checking and analyzing the post layout timing to see if it meets your design target. You can prepare your STA environment before doing layout, but some parameters need to be changed after layout is done 8) (e.g. pre-layout clock settings v.s. post-layout clock settings). 8)
syn & sta
sta contraint is looser than the syn,because the syn must be over timing contraints.
