Can I purchase a domain, resolve its IP and use that in VNC?
bimbla
Advanced Member level 1
About VNC
Can I purchase a domain name, resolve its IP address and use that in VNC Server (Service mode)?
thanks and regards.
bimbla.
Re: About VNC
Because I have just purchased one for real cheap (Rs. 250/-). If I have a network card installed, even then I will have a fixed ip right?
bimbla.
Re: About VNC
Oki..so you bought a domain name...
Now you want to use "something.yourdomain.com" to point to your VNC server?
I assume you know our IP address of your VNC server then? And DNS A-record is setup accordingly?
Re: About VNC
Yes I will do just that . Thank you. I will keep us posted of the results. Are you running any such server?
bimbla.
P.S. I just tried testing it locally...It opens multiple windows of my desktop, until I right click and say stop.
I am on Win XP.
Re: About VNC
You do not really need a domain name with a fix IP to connect to the VNC server. I have succesfully done VNC or X [not secure though] over dynamic DNS hosts i.e. even over phone lines. The only thing you need is the server properly configure and a way of knowing its IP.
About VNC
I usually use the hostname:desktop_num_of_vnc to connect to vncserver. I also think it has no problem if you can get real IP through DNS server or hosts file...:wink:
