[Help Needed] ADC and RTC using PIC18F4520 in MikroC
sarah.sanchez
Junior Member level 2
Hi all,
I'm working on a project that makes use of RTC and the PIC18F4520's ADC module on MikroC. The code that I drafted (please see below) builds in MikroC but doesn't work on breadboard. The RTC counts up but does not have a display in the LCD the whole time. Instead, it follows the delay of the ADC so the output in the LCD only appears after a few seconds. Does anyone know how to debug this problem? My guess is there's a problem with the placing of the while statements. Any help will be greatly appreciated. Thank you!
unsigned short temp_h1, temp_h2, temp_h3, temp_c1, temp_c2, temp_c3;
unsigned short tempdiff1, tempdiff2, tempdiff3;
char hot1[5], hot2[5], hot3[4], cold1[4], cold2[4], cold3[4];
char seconds, minutes, hours, day, month, year;    // Global date/time variables
unsigned short move, counter1, counter2;
unsigned short initial = 0;
void Init_ADC() {
  ADCON1 = 0x00;
  TRISA = 0xFF;
  TRISE = 0x01;
  TRISD = 0x00;
  Lcd_Init(&PORTD);
  Delay_ms(200);
  Lcd_Cmd(Lcd_CLEAR);
  Lcd_Cmd(Lcd_CURSOR_OFF);
void ADC() {
  Init_ADC();
  while(1) {
  ADCON0 = 0x03;
  temp_h1 = ADC_Read(0);
  EEPROM_Write(0x00, temp_h1);
  ShortToStr(EEPROM_Read(0x00), hot1);
  Delay_ms(500);
  ADCON0 = 0x0F;
  temp_c1 = ADC_Read(3);
  EEPROM_Write(0x06, temp_c1);
  ShortToStr(EEPROM_Read(0x06), cold1);
  Delay_ms(500);
  Lcd_Out(1,1,"h1=");
  Lcd_Out(1,5,hot1);
  Lcd_Out(2,1,"c1=");
  Lcd_Out(2,5,cold1);
  Delay_ms(1000);
  ADCON0 = 0x07;
  temp_h2 = ADC_Read(1);
  EEPROM_Write(0x02, temp_h2);
  ShortToStr(EEPROM_Read(0x02), hot2);
  Delay_ms(500);
  ADCON0 = 0x13;
  temp_c2 = ADC_Read(4);
  EEPROM_Write(0x08, temp_c2);
  ShortToStr(EEPROM_Read(0x08), cold2);
  Delay_ms(500);
  Lcd_Out(1,1,"h2=");
  Lcd_Out(1,5,hot2);
  Lcd_Out(2,1,"c2=");
  Lcd_Out(2,5,cold2);
  Delay_ms(1000);
  ADCON0 = 0x0B;
  temp_h3 = ADC_Read(2);
  EEPROM_Write(0x04, temp_h3);
  ShortToStr(EEPROM_Read(0x04), hot3);
  Delay_ms(500);
  ADCON0 = 0x17;
  temp_c3 = ADC_Read(5);   //RE0
  EEPROM_Write(0x0A, temp_c3);
  ShortToStr(EEPROM_Read(0x0A), cold3);
  Delay_ms(500);
  Lcd_Out(1,1,"h3=");
  Lcd_Out(1,5,hot3);
  Lcd_Out(2,1,"c3=");
  Lcd_Out(2,5,cold3);
  Delay_ms(1000);
  /*tempdiff1 = temp_h1 - temp_c1;
  tempdiff2 = temp_h2 - temp_c2;
  tempdiff3 = temp_h3 - temp_c3;*/
/*  if (tempdiff1 >= 80 && tempdiff2 >= 80 && tempdiff3 >= 80)
      PORTE.F1 = 1;              // port RE1 on
    else
      PORTE.F2 = 1;              // port RE2 on   */
//--------------------- Reads time and date information from RTC (PCF8583)
void Read_Time() {
  Soft_I2C_Config(&PORTC, 4, 3); // Initialize full master mode
  Soft_I2C_Start();               // Issue start signal
  Soft_I2C_Write(0xA0);           // Address PCF8583, see PCF8583 datasheet
  Soft_I2C_Write(2);              // Start from address 2
  Soft_I2C_Start();               // Issue repeated start signal
  Soft_I2C_Write(0xA1);
  seconds = Soft_I2C_Read(1);     // Read seconds byte
  minutes = Soft_I2C_Read(1);     // Read minutes byte
  hours = Soft_I2C_Read(1);       // Read hours byte
  day = Soft_I2C_Read(1);         // Read year/day byte
  month = Soft_I2C_Read(0);       // Read weekday/month byte
  Soft_I2C_Stop();                // Issue stop signal
//-------------------- Formats date and time
void Transform_Time() {
  seconds  =  ((seconds & 0xF0) >> 4)*10 + (seconds & 0x0F);  // Transform seconds
  minutes  =  ((minutes & 0xF0) >> 4)*10 + (minutes & 0x0F);  // Transform months
  hours    =  ((hours & 0xF0)  >> 4)*10  + (hours & 0x0F);    // Transform hours
  year     =   (day & 0xC0) >> 6;                             // Transform year
  day      =  ((day & 0x30) >> 4)*10    + (day & 0x0F);       // Transform day
  month    =  ((month & 0x10)  >> 4)*10 + (month & 0x0F);     // Transform month
  EEPROM_Write(0x20, seconds);
  EEPROM_Write(0x21, minutes);
  EEPROM_Write(0x22, hours);
//-------------------- Output values to LCD
void Display_Time() {
   Lcd_Chr(1, 6, (EEPROM_Read(0x22) / 10) + 48);
   Lcd_Chr(1, 7, (EEPROM_Read(0x22) % 10) + 48);
   Lcd_Chr(1, 9, (EEPROM_Read(0x21) / 10) + 48);
   Lcd_Chr(1,10, (EEPROM_Read(0x21) % 10) + 48);
   Lcd_Chr(1,12, (EEPROM_Read(0x20) / 10) + 48);
   Lcd_Chr(1,13, (EEPROM_Read(0x20) % 10) + 48);
//------------------ Performs project-wide init
void Init_Main() {
  TRISD = 0;
  PORTD = 0xFF;
  TRISD = 0xFF;
  TRISB = 0x00;
  TRISE = 0x00;
  ADCON1 = 0x0F;
  T0CON = 0xF8;
  Delay_ms(200);
  Soft_I2C_Config(&PORTC, 4, 3);         // Initialize Soft I2C communication
  Lcd_Init(&PORTD);                // Initialize LCD
  Delay_ms(200);
  Lcd_Cmd(Lcd_CLEAR);       // Clear LCD display
  Lcd_Cmd(Lcd_CURSOR_OFF);  // Turn cursor off
  Lcd_Out(1,1,"Time:");
  Lcd_Chr(1,8,':');
  Lcd_Chr(1,11,':');
//----------------- Main procedure
void RTC() {
  Delay_ms(500);
  Init_Main();               // Perform initialization
  while(1) {
    Read_Time();             // Read time from RTC(PCF8583)
    Transform_Time();        // Format date and time
    Display_Time();          // Prepare and display on LCD
    //determine which LED yung maglight
    if((EEPROM_Read(0x22)==10) && (00<=EEPROM_Read(0x21)<=30))
      PORTB = 0x01;
      else if((EEPROM_Read(0x22)==10) && (30<=EEPROM_Read(0x21)<=59))
      PORTB = 0x02;
      else if((EEPROM_Read(0x22)==11) && (00<=EEPROM_Read(0x21)<=30))
      PORTB = 0x04;
      else if((EEPROM_Read(0x22)==11) && (30<=EEPROM_Read(0x21)<=59))
      PORTB = 0x08;
      else if((EEPROM_Read(0x22)==12) && (00<=EEPROM_Read(0x21)<=30))
      PORTB = 0x10;
      else if((EEPROM_Read(0x22)==12) && (30<=EEPROM_Read(0x21)<=59))
      PORTB = 0x20;
      else if((EEPROM_Read(0x22)==13) && (00<=EEPROM_Read(0x21)<=30))
      PORTB = 0x40;
      else if((EEPROM_Read(0x22)==13) && (30<=EEPROM_Read(0x21)<=59))
      PORTB = 0x80;
      else if((EEPROM_Read(0x22)==14) && (00<=EEPROM_Read(0x21)<=30))
      PORTE = 0x01;
      else if((EEPROM_Read(0x22)==14) && (30<=EEPROM_Read(0x21)<=59))
      PORTE = 0x02;
      else
      PORTE = 0x04;
    //determine pang-ilang counter
      counter1 = 0;
      counter1 = 1;
      counter1 = 2;
      counter1 = 3;
      counter1 = 4;
      counter1 = 5;
      counter1 = 6;
      counter1 = 7;
      counter1 = 8;
      counter1 = 9;
      else
      counter1 = 10;
      //counter1 in seconds
      /*for(counter1=0; 0<counter1<10; counter1++) {
      move = initial + counter1;
      if (10<=(EEPROM_Read(0x22))<=13)
      PORTB = move;
      else PORTE = move;
      //counter2 in minutes
      if(((EEPROM_Read(0x21)==30) && (EEPROM_Read(0x20)==00)) ||
      ((EEPROM_Read(0x21)==59) && (EEPROM_Read(0x20)==59)))
      move++; */
void main() {
  ADC();
  RTC();
You can break the codes up and see where the cause of it not working. With a full code like this, you might have trouble finding where :)
thank you very much for the help :) it finally worked :)
