How to open web page using wavecom AT-commands?
saesaria
Member level 1
Indonesia
AT commands for SIM com and wavecom are slightly different... download the wavecom AT commands and try.....
---------- Post added at 14:00 ---------- Previous post was at 13:59 ----------
When it says you are not getting carrier that means it is not able to establish the connection with any thing.....
I've downloaded the wavecom AT-Command from here and now I'm trying to follow the commands, but I want to know what matter caused my modem got NO CARRIER in return?? I've follow the sequence.
thanks
Hi!
I've tried the sequence of at-commands but then I got ERROR return in +CGACT, here is the sequence
AT+CGDCONT=1,"IP","internet";+CGDCONT=1,"IP","TELKOMSEL"
OK
AT+CGDCONT?
+CGDCONT:1,"IP","TELKOMSEL" , , 0,0
AT+CGQREQ=1,1,4,5,2,14
OK
AT+CGQMIN=1,1,4,5,2,31
OK
AT+CGATT=1
OK
AT+CGACT=1,1
ERROR
AT+CGACT?
+CGACT:0,0
+CGACT:1,0
OK
AT+CGACT=?
+CGACT:(0-1)
OK
Why the +CGACT return is ERROR? I've no idea about it.
And about AT+CSQ? it also return ERROR:?:
thanks.
Hi ckshivaram!
AT+CSQ? isn't working for my modem, but AT+CSQ (without question mark)
AT+CSQ
+CSQ: 12,0
OK
I got the completed reference to do what I wanted, but it's for SIMCom modem.
-> AT+CGATT=1 //Attach to GPRS Service
<- OK
-> AT+CGDCONT=1,"IP","<Your APN Name>" //Define PDP Context (cid, PDP type, APN)
<- OK
-> AT+CDNSCFG="xxx.xxx.xxx.xxx","xxx.xxx.xxx.xxx" //Configure primary and secondary Domain Name Servers
<- OK
-> AT+CSTT="<Your APN Name>","<User ID>","<PASSWORD>" //Start Task & set APN, User ID, and password
<- OK
-> AT+CIICR //Bring up wireless connection with GPRS - THIS MAY TAKE A WHILE
<- OK
-> AT+CIFSR //Get Local IP address
<- xxx.xxx.xxx.xxx //returns IP address assigned to your module
<- OK
-> AT+CIPSTATUS //Get Connection Status
<- OK
<- STATE: IP STATUS //returns status of connection, needs to be 'IP STATUS' before you can connect to a server
-> AT+CIPHEAD=1 //Tells module to add an 'IP Header' to receive data
<- OK
-> AT+CDNSORIP=1 //Indicates whether connection request will be IP address (0), or domain name (1)
<- OK
-> AT+CIPSTART="TCP","www.google.com","80" //Start up TCP connection (mode, IP address/name, port)
<- OK
<- CONNECT OK //Indicates you've connected to the server - this command may take time to give this response
-> AT+CIPSEND //Issue Send Command
<- > //wait for module to return '>' prompt to indicate it's ready to receive data
-> GET / HTTP/1.1 //Send data - this example is an HTTP request for the google
-> Host: http://www.google.com
-> Connection: Keep-Alive
-> Accept: */*
-> Accept-Language: en-us
<- //data from server returned - Server will return data here
And then I tried to follow it, but of course using wavecom AT+commands
AT+CGATT=1
OK
AT+CGDCONT=1,"IP","INTERNET";+CGDCONT=1,"IP","3gprs"
OK
AT+WIPCFG=1 //START IP STACK
OK
AT+WIPBR=1,6 // OPEN GPRS BEARER
OK
AT+WIPBR=2,6,11,"3gprs" //SET APN NAME
OK
AT+WIPBR=2,6,0,"3gprs" //SET USERNAME
OK
AT+WIPBR=2,6,1,"3gprs" //SET PASSWORD
OK
AT+WIPBR=4,6,0 //START GPRS BEARER
OK
AT+WIPCREATE=2,1,"www.google.com",80 //CREATE TCP CLIENT
OK
+WIPREADY: 2,1
Then how to send http request now? I haven't found yet the similar AT+CIPSEND in wavecom AT+Command.
I want to send "GET / HTTP/1.1"
Perhaps you can help me.
thank you
AT+CGATT=1
OK
OK
OK
OK
OK
OK
OK
OK
OK
+WIPREADY: 2,1
i am using modem wavecom fastrack extend fxt009... but i can't execute those command above
at+wipcfg=1
ERROR
anyone help me
thanks
I think you have not loaded "wipsoft.dwl"
just load that and try, at+wipcfg=1 will work
and other wip commands also will work
sorry, not having "wipsoft.dwl" currently with me, get that from other source and load it
good luck
chetan TB
good luck
chetan TB
Thanks for this information . can you give us the link to download "wipsoft.dwl" ?
and if you may give us the instruction to install it .
