I2C Communication between two PIC18 microcontroller
pjohn
Newbie level 6
Dear All,
I am looking for an example project or tutorial that utilizes C language or Microchip Library to configure two PIC 18 using I2C. Any help or direction will be highly appreciated.
Best Regards
Reactions: pjohn
    pjohn
Thanks very much for your help
The example code need the MCC18 compiler library, but I am using the PIC18F45K22, I found that it is not supported by the MCC18 library.....
I will try to #define I2C_V6 in my code to use the "i2c.h" library
Also, in the example code, why it does not need to send stop bit to terminate the communication?
Thanks
have you downloaded the latest version of MPLAB and MCC18 ?
my version of mcc18 picks up the include OK
#include <p18F45K22.h>
The required subroutine is not in pic18f45k22.h.
They are in i2c.h and pcconfig.h (in C:\MCC18\h)(I attached here with .txt extension)
In the pcconfig.h, the code is like:
#ifdef   __18F65K22
     #define I2C_V6_1
There is no __18F45K22...
and in i2c.h, the code is:
#ifdef I2C_V6_1
... //I2C function
I tried to add a code in my main.c to use the function in the i2c.h:
#include  <i2c.h>
#define I2C_V6
but I get an error message :
main.c:308:Warning [2058] call of function without prototype
  • i2c.txt
  • pconfig.txt
which function has no prototype?
you can usually ignore the warnings, if the project builds OK try to load and run it
I choose to rewrite the function in my project.
Btw, in your example code, why it does not need to send stop bit to terminate the communication?
