how to program PIC16f84 using C
kandy2015
Hi everyone, pls I need help on how program my PIC16f84 using C programming language. Thank in advance for every help given.
Do you already have a compiler, wich one is it?.
Compilers generates a output file, normally it is a intel 8 bit .HEX format, that file you can use in most PIC programmers.
What is your specific doub?
You can use MPLAB IDE tool to download the code in your micro controller.
Chanchal
---------- Post added at 10:09 ---------- Previous post was at 10:07 ----------
kindly please describe in more details if you have more query on that.
You can use C compilers like MikroC, MikroC PRO, PIC C (or any other supported) to write C program on an editor and compile it to generate Intel-format-hex file that can be executed inside the PIC.
To program the PIC, you need programmer circuit (So many in JDM type, Pickit2 etc.) and software(PICkit2, WinPIC, Winpicprog, etc.) to operate it from PC. They send generated Intel Hex format file to PIC program memory.
See PIC microcontroller - Wikipedia, the free encyclopedia
Check this link:
Also, attached is the simplest programmer you can find for programming the PIC16F84
  • PIC 16F84A Programmer.rar
