interfacing SD/MMC card with AVR microcontroller
akshay985
Member level 4
maharastra,india
I m working on ATmega16 and trying to interface SD/MMC card in SPI mode only
why the voltage levels drop after card is inserted
your supply is getting shorted .. same problem i had ,, and i got it rectified after finding this fault
---------- Post added at 22:48 ---------- Previous post was at 22:47 ----------
which module are you using to insert the card... any readymade module or you developed it
what is the voltage of AVR Mcu?:grin:
if it's 3.3volts ok,if it's 5 volts,you need a 3.3v reg for sd card and put voltage divider resistor on spi line ,if your sd card was on 5 volts,may be shorted,fried...
Reactions: x40
    x40
You must use a resistor between the mcu and the sd card or use shift level ic like HC244 or HC4050 fed with 3.3 V.
