SOURCE CODE NEEDED in C for frequency counter
ajit123456
Newbie level 3
Recently I visited the page **broken link removed**
Now I'm very much interested to build the circuit with modification to use it as a tachometer(or rpm meter).The hex file is working correctly for frequency meter.
But the source code I guess is intentionally posted with errors and incomplete.
Please anyone give me the source code for the same.
All circuits are given in the .rar file
Thanks.
  • Frequency-Counter.rar
while I am ignorant of C language,
1. I remember somewhere that the file should end with "while1",I did not find any such.
2. __config .... is used in asm
3. you need to know basically which C is this as there are many variants.
4. the include files , especially the delay.c is needed for any compilation.
PS: the C is Hi-Tech C, as indicated in article
the definitions were modified and a new file attached. you may even delete the"delay.c"
Can you try this file please?
  • Freq Counter-C.rar
Thanks.
Check this out : EasyPIC6 Project 1. Frequency/RPM meter - 12th Oct 2009.
You can use it as a Frequency meter (range from 0 to 65000 Hz) or a RPM meter "Tacho" (from 0 to 3900000 RPM)
Some EasyPIC6 projects
ZIP file contains the MikroC PRO source code in C
https://www.romanblack.com/easypic6/EP6_FREQ.zip
and another one :
* PIC16F84 microcontroller
* RS232 text output
* one output per second
* basic frequency range from 0 to 83 KHz with 20 Mhz crystal
* 1 Hz accuracy
* no extra component !
* can be build without MikroC compiler licence !
and make it run on a EasyPic development circuit board.
The C language source code is freely provided !
Simple Frequency Meter
