PIC interface with temperature sensor LM35
ljljlj
Newbie level 1
I have some enquiries about the assign of the PIN as my output.
 setup_adc_ports(PIN_A0);
        set_adc_channel(0);
At first, I set PIN A0 as my output;however, I can't obtain the correct temperature I wanted.
But when I put like this
 setup_adc_ports(PIN_A1);
        set_adc_channel(1);
I am able to obtain the correct result.
Therefore, I try the remaining two pins A2 and A3. Unfortunately, both of the pins also didn't give me the correct result I wanted.
May I know why?
I have check my hardware there is no problem.So, I think is the code giving me the problem.
P.S: I am using CCS compiler.:wink:
May i know it is allow to use only 1 of the Port A pin (channel 0 to read the adc), then the remaining Port A pins to control my motor?
Problem Encountered:
when i only use PIN_A0 interface with the output of LM35, my LCD show me valid temperature result. (29 Celcius or 61 Resolution number.)
But when i enable my motor control pins that also use in Port A, then the temperature result become not correct. I wonder why this could happen
following is my setup:
   set_tris_A(1) ;                 //only pin_a0 to be an input
   output_A(0) ;                  //set all pins to 0 value by default
   setup_adc(ADC_CLOCK_INTERNAL); //use internal clock
   setup_adc_ports(0xE);          //use only pin_a0 as analog input
   set_adc_channel(0);            //set pin_a0 as adc channel
Anyone can point out my setup problem?
Thanks,
sysysy
Thanks,
sysysy
i suggest u to use another port that available..when use port a as analog mood, it cant be digital at the same time..
Thanks for the reply.
I suspect some noise affect the result when share the same port since 10mV is enough give 1 Celcius.
