kokykokykoky
Newbie level 6
Hello All Handsome Man & Pretty Ladies
I am using Cadence 5.1.41 and Mentor Calibre LVS.
For my resistor in schematic: I will key in parameters as W=4 and L=16 which already means 4u and 16u.
After I run calibre LVS: layout => L=16u W=4u
source => L=1.6e+7u W=4e+6u
Property Error.
I check the LVS rule file and the sentence UNIT LENGTH U is present.
Basically, the fundamental error is that it extracts only 4 and 16 from the schematic without the units(micron).
I hope that you would kindly give me some good advise.
Thank you.
Property Error.
Thank you.
