lahrach
Full Member level 3
hi friends I have an error when I build an application on SDK tool (I use Virtex with PPC440)
make -k clean all
rm -rf ppc440_0/code/
rm -rf ppc440_0/include/
rm -rf ppc440_0/lib/
rm -rf ppc440_0/libsrc/
rm -f libgen.log
libgen \
-hw C:/LAHRACH/TP-PowerPC/BasicAPP/SDK/SDK_Export/hw/system.xml \
-pe ppc440_0 \
-od . \
-lp C:/LAHRACH/TP-PowerPC/BasicAPP/SDK/SDK_Export \
-log libgen.log PlatformSTan.mss
libgen
Xilinx EDK 11.4 Build EDK_LS4.68
Copyright (c) 1995-2009 Xilinx, Inc. All rights reserved.
Command Line: libgen -hw
C:/LAHRACH/TP-PowerPC/BasicAPP/SDK/SDK_Export/hw/system.xml -pe ppc440_0 -od .
-lp C:/LAHRACH/TP-PowerPC/BasicAPP/SDK/SDK_Export -log libgen.log
PlatformSTan.mss
INFO:EDK:1740 - List of peripherals connected to processor instance ppc440_0:
- LEDs_8Bit
- RS232_Uart_1
- xps_bram_if_cntlr_0
Staging source files.
Running DRCs.
MFS DRC ...
Runnning DRC for XilIsf library...
ERROR:EDK - xilisf () - No SPI core is addressable from processor ppc440_0.
XilIsf library requires a SPI Core
ERROR:EDK:3193 - issued from TCL procedure "::sw_xilfatfs_v1_00_a::xilfatfs_drc"
line 15
xilfatfs () - Sysace HW module not present or not accessible from this
processor. FATfs cannot be used without this module
Runnning DRC for lwIP library...
ERROR:EDK:3193 - issued from TCL procedure "::sw_lwip130_v1_00_b::lwip_drc" line
12
lwip130 () - No Ethernet MAC cores are addressable from processor ppc440_0.
lwIP requires atleast one EMAC (xps_ethernetlite | xps_ll_temac) core with
its interrupt pin connected to the interrupt controller.
ERROR:EDK:1191 - Error(s) while running DRCs for processor ppc440_0.
make: *** [ppc440_0/lib/libxil.a] Error 2
make: Target `all' not remade because of errors.
make -k clean all
rm -f libgen.log
libgen \
-pe ppc440_0 \
-od . \
libgen
PlatformSTan.mss
- LEDs_8Bit
- RS232_Uart_1
Running DRCs.
MFS DRC ...
line 15
12
