3.3v,1W Zener doid Regulator, need help
Mailar
Bangalore
Hi
I have 12 V battery
and I want to use it to drive 3.3V 30mA micro I/O's
In my circuit i have 3.3v 1W Zener diod with series rsistance Rs,I am not getting stable output When i am varying my source voltage from 3.3 to 12v
And i am using these formula to calculate Rs
Imax = Watts / voltage = 1 / 3.3v = 303mA
Rs= ( Vs - Vz ) / Imax = (12 - 3.3) / 303mA = 28 ohm
can any body help me...
The minimum discharge voltage for 12 V battery shoudln't be below about 10 V, otherwise it gots permanently degraded. With 10 to 14 V input coltage, a zener regulator should manage it.
Of course, you won't get perfect regulation with a zener diode even for a restricted voltage range. It's also not reasonable to apply 300 mA to the zener diode, I think. It would mean less than 10 % efficiency of your "regulator" circuit. In any case, an IC voltage regulator should be preferred, consuming nearly no excess power.
Thanks..! But i am using Variable source input(Vs) from 0-12v.
Yes, obviously regulation can't be achieved over this input voltage range. :smile:
