How to calculate Sine wave frequency using LPC2148
nagarajanj21
Member level 1
Chennai, INDIA
Hai i am working with LPC2148. i need help. how Can we calculate the frequency of the sine wave which is given as a input to the LPC2148 from Function generator.
HI
There are 2 option (both option are frequency dependent)
first option
You need to square the signal and transfer it into the digital domain (signal level)
and measure it using one of the timers as counter with external trigger
Second option
Sample the incoming signal with an ADC and run an FFT algorithm
All the best
Bobi
The microcontroller specialist
Please explain it breify sir.... i can easily calculate it from Square wave... in LPC2148 had 10 bit ADC. if i convert that Analog signal to digital means i get get a values from 0 to 3FF(hex). then how can measure the frequency after that process.....
hi there...
U can set the software interrupt to be generated when the analog sine input value is zero... and increment the value of register on each interrupt , starting from 0...at the end of 1second the register value divided by 2 should give the frequency of sine wave , i guess
