LM1085 constant current regulator not working. Please help!
isaac12345
Member level 2
I tried to wire up the lm1085-adj, as below, as a constant current source(230mA) for charging a battery pack of NiMH cells. Unfortunately, its not working for some reason and I cant seem to figure it out. I think I'm missing something very simple. Please help.
Re: LM1085 constant current regulator not working. Please he
The output of the circuit is on the ADJ pin and not on the OUT pin. So, just move the battery to the ADJ pin. The current will be I = 1.25/R
    isaac12345
It worked!! Thanks a ton!
That was quite odd because I thought , like the LM317T, I would need to connect the battery pack to the output pin.
Is it mentioned somewhere in the datasheet?
With the LM317 the load should also be connected to the ADJ pin, not the OUT pin.
See the diagram at the bottom of page 21:
www.national.com/ds/LM/LM117.pdf
Keith.
