e.fisher
Newbie level 6
Hi.
I have a pulse train created by a model in Matlab. It is saves as an ASCII file of hex time values delimited by carriage returns (I can change the delimiter and data type very easily).
I have a Verilog-A model that is expecting a leading edge unit pulse in order to cause a p-n junction breakdown event.
The ASCII file therefore describes the positions (in time) of each pulse (consistent duration of 50ps). The pulse is used simply to start an analogue event described by the Verilog-A model.
The Matlab code is creating a pulse train with Poisson statistical variation and a complicated modulation as an input, hence I can't implement it easily in cadence.
I need to get my Matlab output signal into the cadence environment.
The university is running Spectre v5.14 which I have already been told may be a problem in terms of file I/O support.
Does anyone have any thoughts, suggestions, work around or can point me in the right direction. File input into Simulink is rather easy, just need to link my model with the Cadence Analog Environment.
Thanks.
Ed (Edinburgh University, UK)
Thanks.
