+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 6
    Points: 630, Level: 5
    shreyassamraksh's Avatar
    Join Date
    Apr 2010
    Bangalore
    Posts
    11
    Points
    630
    Level
    How to increase the gain-BW of a two-stage op-amp?
    Hi everyone,,,,,,,,can anybody help me in increasing the gain-BW of an op-amp,and also gain.......
    Do i want to use any other configuaration added to two-stage opamp......
    Plz Help me out....
    •   Alt24th April 2010, 06:45
      advertising
  2. #2
    Member level 4
    Points: 2,191, Level: 10
    alvays's Avatar
    Join Date
    Jul 2004
    Posts
    76
    Points
    2,191
    Level
    10
    Re: How to increase the gain-BW of a two-stage op-amp?
    I don't know if this will work right, but according to my deduction, it seems like this:
    Av1 = gm1*ro1; Av2 = gm2*ro2, first pole is about: 1/(ro1*gm2*ro2*Cc)
    gm1, gm2 is the first and second stage transconductance
    ro1, ro2 is the first and second stage output resistance
    Cc is the miller compensation capacitance
    So GBW is about Av1*Av2*pole1~gm1/Cc
    that is increase the first stage transconductance and reduce the miller compensation
    For the gain, you should make gm1*ro1*gm2*ro2 to be very large. And because gm1 is proportional to sqrt(I1), ro1 is proportional to 1/I1, and same as gm2 and ro2. Finally, you have to make 1/[lamda1*lamda2*sqrt(I1*I2)] large。
    lamda is the channel modulation coefficient of mos transistor. Larger length of MOS has smaller lamda.
    At the end, it's your tradeoff between all the parameters.
    I think generally it is very hard to construct a two stage opamp with large bandwidth comparing with other structures.
    Alvays
    •   Alt26th April 2010, 06:10
      advertising
  3. #3
    Newbie level 6
    Points: 1,557, Level: 9
    Join Date
    Mar 2006
    China
    Posts
    12
    Points
    1,557
    Level
    9
    pole-splitting compensation/Miller compensation & right-half-plane zero cancellation always used at design.
