VHDL Synthesis, ISE errors and mostly warnings
elockpicker
Member level 4
hi,
I am a newbie in VHDL programming.I have read a few books about VHDL but when I write a code in ISE ,usually I get errors and mostly warnings (which I don't know what to do).
I think I know the syntax of VHDL but I don't know whats going on in FPGAs .
would you please tell me how to know what's going on in FPGAs so I can write synthesizable and efficient code ?
VHDL Synthesis Problems - please help
plz could u clarify what u want to understand exactly?
Re: VHDL Synthesis Problems - please help
thank you very much,the problem is solved.
I needed to add 16 blocks of the same type.
I added it as a component an then used port map 16 times.
read ur synthesizer manual to understand errors and warnings easily.
not every vhdl syntax s synthizable
That's basically a normal way to design logic. VHDL syntax rules have to be kept however, also basic structural requirements, e.g.
a signal can have only one driver at a time, each input signal of a component must be driven (unless specified with a default value).
