What is meant by Critical Path in a circuit?
srinivasansreedharan
Junior Member level 3
USA
Critical Path
What is meant by Critical Path in a circuit? What is its significance?
Re: Critical Path
Critical path simply means the path that violates the timing the most. Usually that is the path with the longest delay.
Re: Critical Path
yes, the longest timing path which cause your chip timing not clean!
