help: how to make a Drill file (gerber) from a *.dxf file?
Andrew77
Member level 3
Rome
I need to extrapolate a DRILL file from a dxf file
I use Linkcad4 and I can make gerber files, but I don't understand how to make a Drill file
thanks in advance
Does the dxf file contain explicite pads or drill positions.? Than it's easy. Otherwise you have to extract pads from the artwork data or insert drill positions manually.
    Andrew77
Re: help: how to make a Drill file (gerber) from a *.dxf fil
The file contains a layer for the holes (vias), but i don't understand how linkcad can extract the file *.DRILL
