How can I Do Internet Connection Via GPRS Modem sim300C?
HHM
Junior Member level 1
Hi
I have a sim300C GPRS Modem with RS232 interface,I need to Connect to the internet with this modem.
I try to do that with creat a Dial_up connection but i got error 777.
I try to do that with Hyper terminal but i got NO CARRIER and when I used
from AT+CEER I got +CEER: GPRS - LCP negotiation timeout
I have some information to connect to the my GPRS SERVER like:
Connection Name:Irancell-GPRS
Bearer:GSM-GPRS/GPRS
APN:mtnirancell
Home Page:**broken link removed**
WAP Proxy:10.131.26.138
Port:9201
Service:CO-WSP
HTTP Proxy:10.131.26.138
Port:8080
Service:HTTP
I am vb.net programmer and I beginner in AT Commands,
Please Help me to create True internet conecction.
for more information This is my Hyper terminals output:
AT+CGDCONT?
+CGDCONT: 1,"IP","10.131.26.138","",0,0
+CGDCONT: 8,"IP","mtnirancell","",0,0
OK
atd*99***8#
CONNECT
~ے}#ہ!}!}?} }<}!}$}&@}#}$ہ#}%}&},<eة}"}&} } } } }'}"}(}"”ہ~~~~ے}#ہ!}! } }<}!}$}&
@}#}$ہ#}%}&},<eة}"}&} } } } }'}"}(}"`à~~ے}#ہ!}!!} }<}!}$}&@}#}$ہ#}%}&},<eة}"}&}
} } } }'}"}(}"(²~~ے}#ہ!}!"} }<}!}$}&@}#}$ہ#}%}&},<eة}"}&} } } } }'}"}(}"ًD~~ے}#ہ
!}!#} }<}!}$}&@}#}$ہ#}%}&},<eة}"}&} } } } }'}"}(}"¸}6~~ے}#ہ!}!$} }<}!}$}&@}#}$ہ#
'}"}(}"}9َ~~ }#ہ!}!&} }<}!}$}&@}#}$ہ#}%}&},<eة}"}&} } } } }'}"}(}"ء}%~~ }#ہ!}!'}
}<}!}$}&@}#}$ہ#}%}&},<eة}"}&} } } } }'}"}(}"‰W~~ }#ہ!}!(} }<}!}$}&@}#}$ہ#}%}&},
<eة}"}&} } } } }'}"}(}"}"b~
NO CARRIER
AT+CEER
OK
atd*99***1#
CONNECT
~ }#ہ!}!)} }<}!}$}&@}#}$ہ#}%}&},<eة}"}&} } } } }'}"}(}"J0~~~~ }#ہ!}!*} }<}!}$}&@
}#}$ہ#}%}&},<eة}"}&} } } } }'}"}(}"’ئ~~ }#ہ!}!+} }<}!}$}&@}#}$ہ#}%}&},<eة}"}&} }
} } }'}"}(}"ع”~~ }#ہ!}!,} }<}!}$}&@}#}$ہ#}%}&},<eة}"}&} } } } }'}"}(}"3#~~ }#ہ!
}!-} }<}!}$}&@}#}$ہ#}%}&},<eة}"}&} } } } }'}"}(}"{q~~ }#ہ!}!.} }<}!}$}&@}#}$ہ#}%
}&},<eة}"}&} } } } }'}"}(}"£‡~~ }#ہ!}!/} }<}!}$}&@}#}$ہ#}%}&},<eة}"}&} } } } }'}
"}(}"ëص~~ }#ہ!}!0} }<}!}$}&@}#}$ہ#}%}&},<eة}"}&} } } } }'}"}(}"µى~~ }#ہ!}!1} }<}
!}$}&@}#}$ہ#}%}&},<eة}"}&} } } } }'}"}(}"‎¾~~ }#ہ!}!2} }<}!}$}&@}#}$ہ#}%}&},<eة}
"}&} } } } }'}"}(}"%H~
NO CARRIER
AT+CEER
OK
see the FAQ on this page about making a GPRS connection:**broken link removed**
I read your posts in **broken link removed** do it and I got IP 10.x.x.x
but I need to the browse web pages,use from ICMP in cmd for ping.
you know?I dont know difrence between ATD*99***8# and AT+CIICR
How can I create dial-up connection via simcom300 with connection wizard?
please Help me
please look at this **broken link removed** (step by step pictures) and tell me your advice.
Added after 2 hours 56 minutes:
I Did like this solution http://www.nowsms.com/beta5/DialUpGPRS.htm
and dial-up connection established successfuly , but I cant browse web sites(yahoo,google,...)via IE and also I cant ping any IPs.
I take print screen from my connection status an attached it,please tell me where is the problem?
thanks for you attention
please Help me
If you are trying to send data to an online file, look at this
Itwork fine to send text data to a text file. The same when recieving data from a text file.
ati
SIMCOM_Ltd
SIMCOM_SIM300
Revision:1008B15SIM300M32_SST34HF3284_MULTIPLEXIP
OK
at+cipmux?
+CIPMUX: 1
OK
at+cstt
OK
at+ciicr
OK
at+cifsr
10.76.58.102
AT+CIPSTART=0,"TCP","205.234.235.188",21
OK
0, CONNECT OK
+RECEIVE:0,310
220---------- Welcome to Pure-FTPd [TLS] ----------
220-You are user number 4 of 50 allowed.
220-Local time is now 10:48. Server port: 21.
220-This is a private system - No anonymous login
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
at+cipsend=0
> user xxxxxx
SEND OK
+RECEIVE:0,40
331 User infolog OK. Password required
at+cipsend=0
> pass xxxxxx
SEND OK
+RECEIVE:0,92
230-User infolog has group access to: infolog
230 OK. Current restricted directory is /
at+cipsend=0
> pasv
SEND OK
+RECEIVE:0,52
227 Entering Passive Mode (205,234,235,188,145,83)
AT+CIPSTART=1,"TCP","205.234.235.188",37203
OK
1, CONNECT OK
at+cipsend=0
> cwd simcom
SEND OK
+RECEIVE:0,38
250 OK. Current directory is /simcom
at+cipsend=0
> stor sim.txt
SEND OK
+RECEIVE:0,30
150 Accepted data connection
at+cipsend=1
> hello from infolog
SEND OK
at+cipsend=0
> bye
SEND OK
1, CLOSED
0, CLOSED
Hi meyerlo,
I am using Sim_300, I am trying to do same thing, i.e transferring the file from client to server using FTP using ACTIVE mode as Sim_300 not supporting two connection unlike in ur case, i am getting ERROR 420 couldn't open the port at client side..., Also At+CIPSEND command's prototype is different than what u r sendng.... its like at+cipsend ="TCP","server IP",21.. hey please help i have tried a lot and stuck now,....
Commands are running properly but data is not transferring server showing empty file...... How do i proceed??....
Thanks...
