PCB Routing isolate copper pcb Etching
goomozo
Newbie level 2
i dont understand some thing
i know how to make pcb using etching using chemical liquid.
but what about Isolate Routing method ? i saw some video show that making milling & drilling but how to remove ( isolate) the copper ? still all the board is copper
The copper is milled from the fibreglass material using small high-speed grinding tools.
The isolation areas have no copper!
I have this facility but still prefer chemical etching :).
thanks for your reply
but do you mean it is two board attached (Paste) Together ? i did not under stand ?
because i saw in the video in youtube that the full board is copper ?
It is just a normal single or double-sided copper-clad board.
It is a sheet of fibreglass and a solid sheet of copper stuck together.
normally,double side board means two sides of copper and the middle is Fibreglass without copper.
Visit the T-Tech website. We have complete systems starting at 7K that will allow you to isolate and mill copper PCB's. **broken link removed**
