[Question] LED blinking + brightness (using PWM + Timer)
wcgan
Member level 2
Hi all,
I have a project, below is the requirement:
-> Control LED brightness + blinking rate(OnTime and OFFtime).
I am able to control the LED brightness using PWM.
My idea is using Timer to set the blinking. How can I compile the PWM and TIMER together?
Microcontroller: Freescale (MC9S08JM16)
example:
I need to set the LED as below state:
LED blinking (OnTime:500ms, OffTime:500ms, Brightness:50%)?
Thanks for your help.
Regards,
wcgan
Sounds to me like you do not know well how to use timers.
Use interrupt on timer overflow. In this interrupt function set a int flag = 1.
In your main program code ... whatever it is just use if condition if in a loop... if flag is 1 then "do something" do something is done then flag is 0. next time loop checks the statement it will just will pass "do something" part and thats all you need.
To do the bilking part you need to turn PWM on or off in "do something" if flag is 1.
