choosing IGBT modules in regard to minimum operating voltage
invermet
australia
i wish to construct an inverter for wind turbines up to 50 kW
Can anyone recommend how to choose IGBT modules with the broadest DC input range ?
and what parameters to use when setting the cut-in point
I would like the cut-in level to be at least down to 140 VDC , and may be as high as 780 VDC
Output will be set at 50 Hz , 415 VAC 3 phase ( Australia )
Solar inverters tend to have a narrow input range , while wind powered have broader fluctuations of minimum and max voltage .
There will not always be low voltage AC supply on site , so do i need to have a backup battery to run the logic and driver circuits operated by a turbine blade movement sensor to prevent the battery being run flat when there is no wind , or is there a better way to configure the circuit so no back up battery is required ?
i would also have low voltage requirements to operate condition monitoring and data uploads . ( 5 VDC and 12 VDC ) but i can run a standalone power supply for that .
any advice gentlemen ?
( and ladies if present )
By the close loop control in digital mode you can control the DC i/p of 140V to 740V.
To choos IGBT consider the max i/p voltage and current.
Re: choosing IGBT modules in regard to minimum operating vol
thankyou
I have been given some Fuji 6MB1300U 6 pack modules ( 1200 V - 300 A )
Can anyone suggest ideal drivers for this function ?
Concept look very good but $ 500 each for driver and base board
Fuji used to recommend the EXB 851 or VLA 517-01R driver but now point me at the Concept one above
next question , logic controller and compiler
anyone got product preferences for efficiency , ease of setup and reliability , plus of course minimum cost of components and labour ?
thankyou
:D[/url]
