How to see Net length in Altium designer?
mobinmohandas
Newbie level 5
bangalore
I wanted to see the length of the trace for length matching .But when i click its taking the segment instead of the entire trace or net.How do i see the total netlength ??????
hi
while we are doing interactive routing, the bottom tab shows the total netlength.
other way is use a filter. try to use the function netlength()
hope this info. helps.
Added after 8 minutes:
hi
do this. select the whole net for which you want to find length using a filter (say in net etc..) and then go to Reports -> measure selected objects. This should give the total length of the net.
if this helps...plz click on 'helped me'
