a question on modelsim5.7g when compiling verilog codes
Marcolm
Newbie level 3
modelsim5.7g
help~(i'm new in this field) as the subject says, when compiling a verilog
program with modelsim,it says:
# Reading E:/Verilog/Modeltech_5.7g/tcl/vsim/pref.tcl
vlog -reportprogress 300 -work work {E:/Verilog/Modeltech_5.7g/examples/counter.v}
# Model Technology ModelSim SE vlog 5.7g Compiler 2003.10 Oct 10 2003
# ** Error: (vlog-19) Failed to access library 'work' at "work".
# No such file or directory. (errno = ENOENT)
is there anything i'v set wrong?if a library is needed,where can i download it?
error: (vlog-19) failed to access library
Yes. I think you are new.
The problem is that you haven't creat the work library.
If it is MS window
File-> new -> library -> (accept default setting and the library name of work) click ok.
or
use commands:
vlib work
vmap work work
There is a tutorial in the Modelsim help. do lessions step by step. u can get lots from it.
Reactions: NGie
    NGie
vlog-19 failed to access library
Thanks a lot. "There is a tutorial in the Modelsim help. do lessons step by step. u can get lots from it." I'll remember it.
