question : tuning for active RC filter corner frequency
linuxwinner
Newbie level 6
corner frequency
Hi folks,
There is active RC filter with frequency tuning circuit. The tuning circuit results indicate that the RC time constant tends to be large. But the bandwidth of the filter tends to be wide. Is there any factor introducing the discrepancy? Thanks!
tuning
I like to answer you - however, I don´t understand your question, sorry.
rc frequency chart for germany
Thanks for your intention! The situation is that RC variation can vary the corner frequency of active RC filter. For keeping track of the RC variation, tuning circuit is used.
rc filter
Yes, but what is your problem now ?
rc circuit corner frequency
The problem is that:
Tuning circuit detects that master RC time constant is large. Large RC time constant means that the slave RC in active RC filter should be also large such that bandwidth of the filter should be narrow. But actually, the bandwidth of the filter is wider than expected. How come there is discrepancy?
calculate rc corner frequency
It would help a lot if you would show us a drawing from the circuit.
active rc filter
Yes, I agree. How could we know without any drawing?
rc filter circuit
As I understand is that the reference circuit indicating that 1/RC is lower than your reference clock frequency. But the change on the filter circuit is that the bandwidth is set to higher frequencies.
This is correct!
If you verify both, the reference tuner and the filter and apply the same process/temperature depend RC, the filter sould be with the tolerance or resolution of the setting method.
