port definition for microtrip dipole antenna, EMDS/Momentum
mikekan
Member level 4
definition of microstip dipole antenna
hi all,
I'd like to ask how many ports for dipole simulation in EMDS/Momentum? 2ports or 3ports (the third port is for Ground plane)
for microstrip dipole antenna simulation, I wonder that I should use port definition iSinn EMDS, ADS 2009 as the following:
Port 1: Single Mode
Port 2: Single Mode
or,
Port 1: Differential mode (Associated with port number: 2)
port 2: Differential mode (Associated with port number: 1)
is that right or I should declare 3 ports: port 1, port 2 and another port 3 for Ground?
Anyone please helps me?
ports in momentum
The right port assignment for dipole is:
Port1: Differential mode (leave the association textbox empty)
Port2: Differential mode (association with port number:1)
There is no need for a third port ground.
Make sure that the two ports are on the same plane, and keep the distance between them as minimum as possible.
Regards
Re: port definition for microtrip dipole antenna, EMDS/Momen
2 Ports
Port 1:internal port
Port2:Ground ref
