HELP ! MODELSIM PE student version license issue
Vincent Girard
Newbie level 6
modelsim license
Hi my friends,
I really need your help !
Did someone had the following message from MODELSIM student version.
I've just downloaded MODELSIM PE student version from www.model.com
What does that mean ? I did nothing special for the license issue.
Do I need to add some kind of extra license file somewhere ?
Thanks in advance :
This is the message.
// Copyright 1991-2009 Mentor Graphics Corporation
# // All Rights Reserved.
# // THIS WORK CONTAINS TRADE SECRET AND
# // PROPRIETARY INFORMATION WHICH IS THE PROPERTY
# // OF MENTOR GRAPHICS CORPORATION OR ITS LICENSORS
# // AND IS SUBJECT TO LICENSE TERMS.
# // NOT FOR CORPORATE OR PRODUCTION USE.
# // THE ModelSim PE Student Edition IS NOT A SUPPORTED PRODUCT.
# // FOR HIGHER EDUCATION PURPOSES ONLY
# vsim work.test_counter
# ** Error: ModelSim PE Student Edition license key file not found at
C:\Modeltech_pe_edu_6.5a\win32pe_edu\..\student_license.dat.
# ** FATAL ERROR: ModelSim PE Student Edition licensing failure due to
one or more problems with the license key such as:
# - it is not found
# - it has expired
# - it is not for this user
# - it is not for this computer
# - it is not for this version of ModelSim PE Student Edition.
# Please go to http://www.model.com and download an updated copy of
the ModelSim PE Student Edition.
# Error loading design
vsim work.counter
# vsim work.counter
modelsim student license problem
Don't tell me no one have ever had this problem, Come on !
i expect ur r working in windows. U need to request for a license file from Mentor. Details should be on their site. License file would be around 1KB and u need to set an environment variable "LM_LICENSE_FILE" pointing to this file
modelsim license student
you'd better use it in the linux machine!
modelsim student edition download
once u complete the installation u will be redirected to model/xilinx website for registration.then a license fill of 1 kb will be sent to u. save this license.dat file in LM_LICENSE_FILE in any folder.go to my computer.right click properties, advanced. Set variable give this LM_...._FILE and set the path of license.dat file as its variable.
then ur tool should be working
Thanks a lot ksrinivasan, I had the same problem but my tool is working now.
