hntko
Member level 1
material: rogers rt/duroid 5880(tm)
Hi all,
I am a beginner with HFSS. I have its verson 10. Now, I try to design a printed dipole antenna using HFSS. The project have been design alreadly but it seems that there maybe some problems. As can be seen from the S-parameter result figure in this project, the antenna in the project works at quite different frequency (around 5GHz) than that I expected (around 2,4 GHz). Here are some detailed information:
1. The patch: 50mm x 50 mm x 1.475 mm, material: Rogers RT/duroid 5880 (tm)
2. The dipole:
Length of arm: 22 mm
Length of the whole dipole: 46 mm
Width: 3mm
Material: pec
3. Excitation:
Port: Wave port
Type: Using SMA connector which was downloaded from this forum
The project is attached with this message. Please check my project and show me if there is any problem.
Thank you so so much!
Le
Hi all,
2. The dipole:
Width: 3mm
Material: pec
3. Excitation:
Port: Wave port
Le
