yan25
Newbie level 3
tanks for all responses. the multiplier must have A[5:0]-input, which is a bus for adresses, D[5:0]-output which is a bus for data informations and it gets the data value which is stored at the adress of the input A ;OE(output enable) -it is the input which activates the output D- if OE='1' then at the out D it will be the value which is stored in the memory, or else, the bits of output D will be in a state of high impedance; CS (circuit select)- activation input of circuit. if CS='1' the circuit will decode the adress input and will supply the output (if OE='1') value stored at the specified address.else (if CS='0'), the circuit will not decode adress input, and at output D the bits will be in a state of high impedance.
