AVR Programming Related - programming devices
movie_freak
Member level 5
I burn my hex file into the AVR using the ISP programmer and AVR studio software. if i have a hex file let's say the source contains some unique number like product_id or serial_no.
Is there a way or possiblility, or probably how can i program different devices with different(unique) serial number everytime, with a single hex file? (without changing the source manually and building the source again and again)
Many Thanks,
Surya:idea:
burn the serial number in the eeprom of the avr should be a good idea ?
Re: AVR Programming Related
Hai
Another Method is using a hex editor
MicroCon
yes its possibe and simple
First find where in the hex file the serial no. product id are been stored
by changing in the main code you will come to know the place
then change that value and the respective CRC value (last byte of the line)
then check it will change the parameters without changing the code
you can use simple editors like notepad to chane the values the only thing is the CRC at the last of the line
