inverter design - sinosoidal PWM inverter's output question
mess123
Member level 5
inverter design
A sinosoidal PWM inverter's output is fed to the step up transformer. What will be the output waveform from the transformer like? Won't the long duration pulse be lost because of the transformer's differentiation action?
Re: inverter design
inverter makes 50Hz sine by PWM. The output of the inverter is pulsey but they smooth it out with filters....then its just normal 50Hz AC of whatever RMS value.
