ORCAD capture link to Allegro PCB layout problem
maocon
Newbie level 1
link orcad schematic to allegro pcb
Recently, I reinstalled the Cadence PSD_14.2 after Uninstalled the same software version. I encountered problem with the link between Allegro PCB layout to Capture CIS schematic. When I hilighted a component in Allegro, the Capture schemaitic does not respone with a hilighted component. Previously, this feature worked. Now, with the same software re-installed, it no longer work.
I did ran a netlist in Capture and imported Logic again to Allegro, but the link between Allegro and Capture still failed. I did check where the netlist file directory are, and it is correct like it used to be.
Anyone have knowledge about this issue please help.
It looks to me like a installation problem .
Are you sure that you haven't received any error during the installation ?
