What type of I2C does a CodeVision for AVR use?
sadat007
Full Member level 4
Pakistan
Does any one knows that the CodeVision for AVR use Hardware or Software I2C in Automatic Program Generator OR its include I2C library?
Like the DS1307 library is using Hardware/Software I2C?
thx
codevision i2c
It uses hardware I2C.
avr i2c
Hrm - not sure about that. I can generate code for I2C and DS1307 for AT90S2313, which has no hardware I2C.
Looking at the .lst file, it appears to be all software I2C ...
-pana
i2c codevisionavr
-pana
Well, I think we're both right.
The tab I2C in the CodeWizardAVR is for software I2C and the tab 2 Wire (I2C) is for hardware I2C.
The tab 2 Wire (I2C) only appears when you have chosen a device with hardware I2C (2 Wire) at the Chip tab.
avr i2c library
2 WIRE I2C is hardware, for but slave mode only as much I understand.
So the libs like DS1307 etc are using software I2C. 8O
