can anyone help with an inverter circuit using sg3524 pwm?
e.d.i
Newbie level 1
sg3524
The sg3524 has a very good advantage over monolithic cd4047 cus the output can be automatically adjust to normal a.c voltage when there is variation in load.
The auto adjust is possible when there is feedback signal to the pin 1 of the ic, the circuit i have worked, but does not have a feedback.
thanks.
circuit of a good inverter
Dear friend, You can get more details and encouragement from this post related to pwm inverter. Good luck
inverter using pwm and feedback
Here it is :
thanks.
Re: sg3524
pls sir send me the circuit of the inverter with the feedback connected.
    V
