need help for PIC 16F84A programming
abc1122
16f84a programming
hie,
Im very new to PIC programming. Have no basic knowledge at all. Am currently doing a final year project.
Below are part of my code:
PORTA equ 05h
TRISA equ 85h
PORTB equ 06h
TRISB equ 86h
org 0 ;reset vector to origin 0
bsf STATUS,5 ;go to BANK 1
movlw PORT_RA ;set RA2 and RA3 as input
movwf TRISA ;move 04h to TRISA
movlw PORT_RB ;set all RB ports as output
movwf TRISB ;move to TRISB
bcf STATUS,5 ;back to BANK 0
there are 2 error in the BOLD.
Message[302] C:\PROJECTS\16F84ATMPO.ASM 101 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\PROJECTS\16F84ATMPO.ASM 103 : Register in operand not in bank 0. Ensure that bank bits are correct.
can somebody help me? Thanks
pic16f84a programming
Look at example 4.1 on page 15 of the PIC16F84 data sheet.
You need to add BSF STATUS RP0 before you write data to the TRIS registers and BCF STATUS RP0 afterwards.
pic16f84 programming
I have both BSF and BCF already. Or should i change the the sequence?
By the way, i have another problem. This is regarding the Link Step Failed.
'SERVICE movlw RA1 ;switching to service line'
Warning[207] C:\PROJECTS\16F84ATMPO.ASM 118 : Found label after column 1. (SERVICE)
thanks
Added after 43 minutes:
i have found the solution.
But i have new error here.
Error - section 'ISR' can not fit the absolute section. Section 'ISR' start=0x00000004, length=0x00000010
What does it mean?
thanks
pic16f84.inc
Hi i think you should write this
#include pic16f84.inc
list p=16f84
bsf STATUS,RP0
movlw b'00001100' ;port ra2, ra3 as input, rest as outut
movwf TRISA
movlw b'00000000' ; port b sa output
movwf TRISB
bcf STATUS,RP0
sorry for my english
movwf trisa
if you use this :
#include pic16f84A.inc
list p=16f84A
you don't need this
PORTA equ 05h
TRISA equ 85h
PORTB equ 06h
TRISB equ 86h
programming pic16f84
What does it mean?
thanks
It may be because your code overwrites Interrupt Vector location 0x0004. Use a GOTO in the beginning like this or show us your full code. May be its something else.
org 0x0000 ;reset vector to origin 0
    goto main
org 0x0020
main
in pic programming what happen trisa
i have my code build successfully.
but i cant write it in my pic. when i program and check the memory status is not correct
16f84a programing
Which programmer are you using ?
pic16f84 register in operand not in bank 0
its ok.. problem solved.. th
