current mode vs. voltage mode PWM control
tdy
Member level 3
Navy
current mode vs voltage mode
I am wandering why for the current control method there is a RS flip-flop be connected after the comparator before sending the driving signal to the swithing gate. But for voltage controller there is not such a block. Can anybody explain?
voltage mode vs current mode
A flip-flop is also used in many voltage mode controllers, e. g. classical 3524. It assures that only one output pulse is generated for each clock periode.
    tdy
voltage mode pwm
can u give some abnormal operation examples for the unintended driving signal?
flip flop pwm
If you don't use a flip-flop or some memory element, then you will suffer noise issues when you turn on the big power switches.
For example, if VM is only using a ramp and capacitor, then when the ramp exceeds the error voltage and you try to turn on the mosfet, switching noise can cause the comparator to flip back from 1->0.
If you have a flip-flop, we only care about the first comparator edge and we toggle the switch on/off cleanly. If you don't have a flip-flop, your converter can give several ON-OFF glitches at the start and end of each switching cycle.
A flip flop is cheap. You need to use one.
Reactions: bajanbruce
    tdy
    bajanbruce
current mode pwm controller
Your explanation is very helpful. Thank you verymuch.
