[SOLVED] Help me with code for serial in parallel out (Xilins Spartan 3E chipset)
dimitarlazarevski
Newbie level 2
Could any one provide me the code for serial in parallel out. It has to have 6 bit out data. The serial in data i have to put it by my hand in binary code. The board is Xilinx Spartan 3E; chipset? XC3S100E; TQ144
BASYS (Basic System Board) Digilent
Thank u
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity jc_top is
Port ( DIN : in STD_LOGIC;
START : in STD_LOGIC;
RST : in STD_LOGIC;
CLK_MAN : in STD_LOGIC;
DOUT : out STD_LOGIC_VECTOR (5 downto 0):="ZZZZZZ");
end jc_top;
architecture Behavioral of jc_top is
signal Buff: std_logic_vector (5 downto 0);
signal tmp: std_logic_vector (5 downto 0);
begin
process(CLK_MAN, RST, START)
variable CNT: integer :=0;
begin
if (RST = '1') then
if(START = '0') then
CNT:=0;
-- DOUT(5 downto 0)<="ZZZZZZ";
tmp(5 downto 0)<="ZZZZZZ";
BUFF(5 downto 0)<="000000";
elsif(CLK_MAN'event and CLK_MAN = '1') then
CNT:=CNT+1;
BUFF <= BUFF (4 downto 0) & DIN;
-- if CNT=5 then tmp(5 downto 0)<="ZZZZZZ"; end if;
if CNT=6 then
tmp(5 downto 0)<= BUFF(5 downto 0);
--DOUT(5 downto 0)<= BUFF(5 downto 0);
CNT:=0;
end if;
end if;
elseif(RST = '0') then
CNT:=0;
end if;
end process;
DOUT(5 downto 0)<=Tmp(5 downto 0);
end Behavioral;
For example: I have to put one slide switch for START, one button for CLK, one slide switch for data in ("0" or "1") and one button for Reset (RST). And I put the slide switch Start in position 1 (Up), and I start to press the CLK button 6 times. And I put the data in (if the slide switch for data is down -> "0", if it's up -> "1"). When I press the CLK 6 times the leds indicate data out. Then I should press Reset button and I want to be reseted. Is this code correct?
Best regards.
