arunjatti
Newbie level 6
Hi all,
Im using a clock divider in virtex 2p , im able to check the clock when implemented in divider module .i.e input is 100Mhz clock output is 1hz clock , but this 1hz clock when im giving to any other module it is showing some prob with skew ettc warning and output is not seen ....
how to divide the clock in Virtex2P (100MHZ) clock to around <1hz a??
and can i give this 1 hz clock to other modules(as in my case its not working)??
thanks in advance
arun
thanks in advance
arun
