ahsanali
Newbie level 5
ones counter
i need VHDL code for ones counter plz help.my email address is : contact2ahsan@yahoo.com
library ieee;
use ieee.std_logic_1164.all;
use ieee.arith.all;
entity ones_count is
port (
clk : in std_logic;
rst_n : in std_logic;
ld_data : in std_logic;
busy : out std_logic;
data_in : in std_logic_vector(7 downto 0);
count : out std_logic_vector(3 downto 0));
end ones_count;
architecture behave of ones_count is
signal data : std_logic_vector(7 downto 0);
signal count_i : std_logic_vector(2 downto 0);
signal sum : std_logic_vector(3 downto 0);
begin -- behave
count <= sum;
process (clk, rst_n)
begin -- process
if rst_n = '0' then -- asynchronous reset (active low)
data <= (others => '0');
count_i <= (others => '0');
busy <= '0';
sum <= (others => '0');
elsif clk'event and clk = '1' then -- rising clock edge
if ld_data = '1' then
data <= data_in;
busy <= '1';
end if;
if count_i /= "111" then
count_i <= count_i + "001";
sum <= sum + data(count_i);
end if;
if count_i = "111" then
busy <= '0';
end if;
end if;
end process;
end behave;
-- __ __ __ __ __ __ __ __ __ __ __
-- CLK _/ \___/ \___/ \___/ \___/ \___/ \___/ \___/ \___/ \___/ \___/ \__
-- _______________________________________________________________________
-- RST_N _____/
-- ______
-- LD_DATA_____________/ \________________________________________________________
-- _____________________________________________________________________________
-- DATA_IN___________AA___________________AA________________AA____________AA___________
-- BUSY _______________/ \______
-- ______________________ ______ ______ ______ ______ ______ ______ ____________
-- COUNT_i___________0__________X__1___X__2___X__3___X__4___X__5___X__6___X__7_____7___
-- ______________________ ______ ______ ______ ______ ______ ______ ______ _____
-- COUNT ___________0__________X__0___X__1___X__1___X__2___X__2___X__3___X__3___X_4___
module top (x, ones);
input [7:0] x;
output [3:0] ones;
assign ones = x[7] + x[6] + x[5] + x[4] + x[3] + x[2] + x[1] + x[0];
endmodule
